1950 f1 numbers - Ford Truck Enthusiasts Forums
1950 f1 numbers
Old 08-21-2014, 11:25 PM
bigmark bigmark is offline
bigmark is starting off with a positive reputation.
1950 f1 numbers
I need some help with my 1950 f1.Iam trying to find out what does the numders stamp on my fire wall mean?I search the threads but cant find anything maybe iam putting the wroung word in the search.
It looks like this
15
sp6121849563
Old 08-22-2014, 12:28 PM
52 Merc's Avatar
52 Merc 52 Merc is offline
52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of
Welcome to the forum. There's a very lengthy thread on the subject. In that string of numbers is your color code, assembly plant, date code and other information. The SP would indicate St. Paul assembly plant. You appear to have way more numbers than is the norm. Post the info and other requested details in the thread here..
https://www.ford-trucks.com/forums/4...n-cut-off.html
Old 08-22-2014, 08:43 PM
Thanks 52 merc I will try that thread
Old 08-22-2014, 10:52 PM
mtflat mtflat is offline
mtflat has a good reputation on FTE.mtflat has a good reputation on FTE.mtflat has a good reputation on FTE.
15 could be light gray. Knowing the color of your truck and serial number would help as SP used numbers for awhile before going to letters for the color.
Most have a stamping something like 15 SP 12L 2345
Sometimes lightly sanding the stamping will bring out details. Shining a light on a shallow angle can also help. Post a clear - if you can.
gearing help/ qestions jg96powerstroker 1994.5 - 1997 7.3L Power Stroke Diesel 21 10-26-2015 10:25 PM
78 f-250 trim 78sd250 1973 - 1979 F-100 & Larger F-Series Trucks 27 08-21-2015 04:06 AM
Help with 1950 F1 original wheel 1964 f100 1948 - 1956 F1, F100 & Larger F-Series Trucks 10 09-24-2014 11:34 AM
Slave cylinder bleeding...??? 95f3507.3 1994.5 - 1997 7.3L Power Stroke Diesel 3 05-23-2014 11:23 AM
1950 Ford F1 Alignment specs 51truck 1997-2006 Expedition & Navigator 1 03-25-2009 08:24 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
