Would like some advise from Mark
Old 08-17-2014, 04:29 PM
The2003Excursion's Avatar
The2003Excursion
The2003Excursion is offline
Is there a junction between this area and the actual transmission case that needs to have a gasket replaced?
Old 08-17-2014, 05:04 PM
EXv10's Avatar
EXv10
EXv10 is offline
http://www.moveras.com/images/transm...sions_left.jpg
There is the gasket in front of the t-case housing and the rear of the bottom pan.
Old 08-17-2014, 05:53 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Mark Kovalsky is offline
Received 1,576 Likes on 1,054 Posts
The seal in the solenoid body can leak fluid into the connector. It takes a new solenoid body to fix this. Unless a lot of fluid gets in there it doesn't cause a problem.
Old 08-17-2014, 06:35 PM
The2003Excursion
Thanks for the image
So I guess the joint at the yellow is not something that is easily serviced/or does not need to be serviced in this situation.
Old 08-17-2014, 07:28 PM
EXv10's Avatar
EXv10
EXv10 is offline
Not easily fixed there. I think the overflow tube ends right about where that leak is also. I would give it a good cleaning there at a quarter car wash and then keep an eye on it.
Old 08-17-2014, 09:50 PM
hav24wheel's Avatar
hav24wheel
hav24wheel is offline
Usually that tail housing just unbolts, and that's it. The other stuff stays inside the trans. Jack it up off the oil pan, take the trans mount loose, unbolt the tailhousing, and replace the gasket. No big deal.
Old 08-17-2014, 10:30 PM
EXv10's Avatar
EXv10
EXv10 is offline
So I guess I am wrong. I shouldn't have assumed anything.
cabloom300
01-04-2018 09:10 PM
Dank Hill
02-25-2016 11:07 AM
JaySVX
11-05-2014 11:19 AM
joegeds
06-22-2013 11:54 AM
Headviking
1999 to 2016 Super Duty
08-13-2010 05:24 PM
Quick Reply: Would like some advise from Mark
