My 67 Ranger
That's what I came up with too. Turns out, the RH door is 67. Looks like the LH door is 68? How did I miss that. That blows. Because the door has been there so long that it has patina'd the same. I guess I'll shop for a door and see what happens.
X2 what Gembone says.
Can you get a good picture of that radio? Not sure what that is.
Definitely do some investigating. Especially the wiring.
Post a picture of the lower rock guard where the turn signals are mounted.
While the grilles are interchangeable, the lower valance or rock guard should be swapped with the correct grille.
You can put a 67-69 grille on a 70-72 truck, the lower valance/rock guard will accept the grille leaving a larger indented area below grille. Not real noticeable unless you know what to look for.
Now, putting a 70-72 grille on a 67-69 requires the lower valance to be replaced. Reason being the indented area for the turn signal housings are smaller and the turn signal housings will not look right. Don't get me wrong it can be done it just looks like crap.
Picture please.
Picture please.
I'd say the dash is all '67, typical heater controls. The radio is likely stock/original. The ***** looks the same design as the heater controls.
'67 RH door, looks like someone replaced the LH door somewhere in an early time.
I'm a diehard FE guy, but for a daily runner, I'd put a 302/T5 in it. You can put a 4.10/4.30 gear in the back for some pep and then have OD to cruise the highway.
Byoung Oh
1983 - 2012 Ranger & B-Series
03-12-2017 09:56 AM
optimusbinder
17
02-06-2005 07:31 PM
MAY
Car/truck Buying Advice
05-13-2002 08:21 PM
