87 ford ranger 2.9 wont start
Old 08-12-2014, 10:30 AM
Alm200's Avatar
Alm200
Alm200 is offline
Fuel pump runs continuously and when i pull the return line off the fuel pressure regulator gas just pours out it does have pressure at the rail fuel pump pressure tested good if you hit it with either it will hit so i know its getting fire and its getting fuel to the rail but it wont start just crank and crank and crank whats wrong???? Also fuel pressure regulator is new
Old 01-20-2015, 11:47 PM
moosey1981's Avatar
moosey1981
moosey1981 is offline
Check the coil and you probably have a bad head gasket.....
Old 01-21-2015, 07:02 AM
f5fordgirl's Avatar
f5fordgirl
f5fordgirl is online now
Having pressure doesn't mean its the right amount, if it hits with either, but won't run, it sounds like the new regulator is bad.
Old 01-23-2015, 05:20 PM
IB Tim's Avatar
IB Tim
IB Tim is offline
Site Administrator
Welcome to FTE....I sent you an email.....
1320stang
08-15-2018 02:07 PM
dcelrod
10-17-2014 11:43 AM
sport1100
1983 - 2012 Ranger & B-Series
08-26-2006 08:48 AM
mltrf
3.0L V6
08-08-2006 04:26 PM
bdonalds
04-04-2001 02:16 PM
Quick Reply: 87 ford ranger 2.9 wont start
