2003 Sport Trac, intermittent starting, like pump won't hold pressure...
No I haven't performed a pressure test, tank was almost empty so I dropped it to pull the pump.
A guy I paid to do a motor swap (50k less miles, installed the timing kit I had bought on 'new' motor) drained the fuel tank, I guess he replaced the pump, the tag on it says tested 02/10/17. Found the remains of the original fuel filter in the tank. Once running it runs fine, no hiccups, its just hard to start on occasion. Pump has maybe 1000 miles on it.
Any chance its the fuel injection pressure damper?
There's a chance it's an issue with the fuel pressure regulator, but you really should check the fuel rail pressure when it is hard to start to determine the chances of that. If you remove the vacuum line to the regulator and there's fuel in the vacuum line, then that regulator is shot and needs to be replaced. That's assuming a couple of things though - 1) Your truck has a fuel pressure regulator instead of a fuel pressure sensor, and 2) The fuel pressure regulator is vacuum controlled.
I haven't checked the service manual to determine if these assumptions are good or bad ones.
-Rod
-Rod
pnp522
02-06-2018 06:46 PM
DJdemon6696
27
12-02-2007 04:43 PM
4x4Junky
09-10-2007 11:05 AM
