Suspension Question - Probably been asked before lol
OK...So truck has 133k on the suspension...you can tell it needs replacing while riding in it lol
Ordered a lift kit...4 inch all around. Skyjacker.
Do not have the tires yet (going with 35s - 315/75/16)....
Bad idea (other than looking stupid lol) to go ahead and install lift kit with stock tires?
I lower a lot of vehicles...never went the other way lol
I can see it looking silly with 265/75/16 tires on a lifted 4 inch excursion lol So I am prepared to be laughed at LOL!! Just going to be a bit before I can get the tires due to funds.
I just forsee it rolling or something due to the smaller tire and the more body roll with the lift kit...not that I am going crazy with the lift...so getting antsy as the parts just showed up and the suspension really needs replacing lol
Here is the look I am going after:
Thanks!
Thanks!
Yup, even with the 1400lb WD spring bars cranked all the way up the stock rear springs were squished. . My goal was to pull the trailer with 1400+ lb tongue weight, run 35"s and sit level while towing. Worked out perfectly and performs very well.
Try and stay away from cement/cinder blocks, they can crack with the kind of weight a vehicle or a boat can exert without being dispersed like foundation for a building.
I've seen this first hand with boats blocked up on cement blocks. Use wood if you can
Leandro Palmature
1999 to 2016 Super Duty
28
08-27-2015 02:55 PM
ItsAFord55
43
04-26-2011 11:02 AM
Ken2600
10-02-2002 07:08 PM
