4inch lift on small tires
Old 04-21-2011, 10:48 AM
ItsAFord55's Avatar
ItsAFord55
ItsAFord55 is offline
ItsAFord55 is starting off with a positive reputation.
im thinking about getting a 4inch suspension lift for my 1991 f150 2wd ..but i dont have money for new tires ..right now i have 31inch nitto terra graps...would this set up look weird?
Old 04-21-2011, 10:53 AM
turnkyle
turnkyle is offline
turnkyle is starting off with a positive reputation.
You could get a decent idea of how it would look by jacking the truck up by the frame. Your suspension should droop about 4".
Old 04-21-2011, 11:08 AM
6CylBill's Avatar
6CylBill
6CylBill is offline
6CylBill has a great reputation on FTE.6CylBill has a great reputation on FTE.6CylBill has a great reputation on FTE.6CylBill has a great reputation on FTE.6CylBill has a great reputation on FTE.
Wouldn't look bad. I have 3 inches in the front and 5 inches of lift in the back on my 4x2. Up close, the truck looks great with the 31 inch tires. From a distance the tires look smaller but not bad. I think 32x11.5's would be perfect.
Old 04-21-2011, 11:26 AM
BRay09's Avatar
BRay09
BRay09 is offline
BRay09 is gaining momentum as a positive member of FTE.
Bill for your pictures it doesn't look like it's lifted that high. That's cool though I like the look of your truck
Old 04-21-2011, 11:29 AM
zxwut?'s Avatar
zxwut?
zxwut? is offline
zxwut? has a good reputation on FTE.zxwut? has a good reputation on FTE.zxwut? has a good reputation on FTE.
Could you keep saving a bit longer until you have the money to do both? Seems like that'd be the best solution.
Old 04-21-2011, 11:40 AM
ItsAFord55's Avatar
ItsAFord55
Well I dont wanna get new tires jus yet cause I jus got them about a year ago
Old 04-21-2011, 11:49 AM
6CylBill's Avatar
6CylBill
6CylBill is offline
Hey B-Ray!
I don't know why but pictures don't capture how much space there is between the tires and truck. It's strange.
Here's what my truck looked like before any lift and hauling a heavy load.
Here's with the lift, no load
Old 04-21-2011, 11:58 AM
Grubbworm's Avatar
Grubbworm
Grubbworm is offline
Grubbworm has a great reputation on FTE.Grubbworm has a great reputation on FTE.Grubbworm has a great reputation on FTE.Grubbworm has a great reputation on FTE.Grubbworm has a great reputation on FTE.Grubbworm has a great reputation on FTE.
Bill, what did you do to get that lift on your 2wd truck? Mine is a 2wd, and I'm looking for something similar.
Old 04-21-2011, 12:25 PM
6CylBill's Avatar
6CylBill
6CylBill is offline
Hey Dave!
I wanted an old school 30 and 40's style military truck stance. Thus the whole lifting adventure.
I lifted mine the wrong way and have paid for it. I strongly recomend to you that you go with a solid 4'' suspension lift. Do a little research, make some phone calls. There are kits and shops who can / will lift a two wheel drive truck.
Just go for a good, solid suspension lift.
Old 04-21-2011, 04:42 PM
IDIDieselJohn's Avatar
IDIDieselJohn
IDIDieselJohn is offline
IDIDieselJohn has a great reputation on FTE.IDIDieselJohn has a great reputation on FTE.IDIDieselJohn has a great reputation on FTE.IDIDieselJohn has a great reputation on FTE.IDIDieselJohn has a great reputation on FTE.
Hows this look?
Not my truck... I don't even like lifts, or big tires for that matter!
Old 04-21-2011, 07:40 PM
ItsAFord55's Avatar
ItsAFord55
Originally Posted by IDIDieselJohn View Post
Hows this look?
is that a 4inch or a 6inch lift?
Old 04-21-2011, 09:23 PM
zxwut?'s Avatar
zxwut?
zxwut? is offline
It looks really goofy.
I think you should wait until you can do both.
Old 04-21-2011, 10:37 PM
IDIDieselJohn
If I remember from the add, it's a 6 or 7" suspension lift.
Old 04-22-2011, 12:02 AM
Skinsfan6's Avatar
Skinsfan6
Skinsfan6 is offline
Skinsfan6 has a very good reputation on FTE.Skinsfan6 has a very good reputation on FTE.Skinsfan6 has a very good reputation on FTE.Skinsfan6 has a very good reputation on FTE.
A 4 inch kit with 31s wouldn't look that bad because it will look like a 4x4 with 2 inches of lift. If I were you I would go with a 6" kit. When I was looking at lift kits for my 4x4 the price difference for different heights was really small given the end result. And you need two more inches to be the same height as a 4x4. I don't know about you but if I had a 2wd I wanted to lift I would be comparing it to lifted 4x4s in terms of looks and ground clearance. Bill's looks pretty good because 1)3 inches in the front really isn't much higher than a stock 4x4, and in the rear it's harder to approximate lift height, so 5" doesn't look like it's too tall, and 2)he has meaty looking tires that look wide for what they are.
But I also agree you should wait until you can afford everything at once. The right tires really make the lift worth it.
If you look in my gallery I have some pictures of my truck before I lifted it with 31s on it. Your truck with 4" should be about 2" higher than mine when it was stock. Should be a decent visual aid.
PS Bill - Your truck is clean! I wish mine was in that good of shape. Someday I'll paint mine...
Old 04-22-2011, 01:10 AM
TexasGuy001's Avatar
TexasGuy001
TexasGuy001 is offline
TexasGuy001 has a very good reputation on FTE.TexasGuy001 has a very good reputation on FTE.TexasGuy001 has a very good reputation on FTE.TexasGuy001 has a very good reputation on FTE.
I wouldn't lift a 2wd truck. Been there done that. Mine is back to stock with 31s and I really like my truck so much better now.
If you lift it and put bigger tires on it, you will need to regear the axle for the larger tires too.
I would go with a 4 inch lift and 32 11.50s if you do it. I think a 6 inch lift on a 2wd is just silly.
Definitley go with a suspension lift if you do it.
Quick Reply: 4inch lift on small tires
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
