fe 390 HELP!!!
Old 08-27-2014, 11:32 PM
fe390fordpower's Avatar
fe390fordpower
fe390fordpower is offline
fe 390 HELP!!!
I got a 75 f-250 and recently been having brake problems I did a full replacement as the rear were almost shot and front needed replaced and I tthen replaced master cylinder and power booster but after I replaced the booster it seems the engine now runs like crap. It refuses to idle and its running very rich I advances the timing and tuned the carb but to no avail. It seems no matter what I do it will not idle. I checked and rechecked all my vacume lines and ignition setup ( points coil etc) and all are fine. Anything would help I am compmetly stumped at this point. I have little experience in this field as this is my first fe 390 iv ever had the pleasure to deal with
Old 08-28-2014, 07:14 AM
69cj's Avatar
69cj
69cj is offline
The new booster appears to have a vacum leak. Unplug the vacum to the booster. If the engine idles that's the problem.
Old 08-28-2014, 10:18 AM
fe390fordpower
I did
I tried that and it didn't help...I sprayed down all of my vacum hoses and connections with either and I even thought that it could be the carburetor gasket where is bolts to the intake but that wasent it either...I talked to a mechanic the other day and he said that if my timing chain had to much slack that could be my problem but he wasent sure. Everybody I ask seems to be stumped when I explain my problem.
tragicsandwich
02-19-2015 06:52 AM
alvald83
07-11-2012 11:21 AM
albcasummit
03-12-2006 04:33 PM
sisu1a
08-31-2005 05:13 AM
BowtieRed
11-03-2003 04:01 AM
Quick Reply: fe 390 HELP!!!
