5.0 issues
Old 08-04-2014, 10:02 PM
ScumbagSteve's Avatar
ScumbagSteve
ScumbagSteve is offline
Question 5.0 issues
So I've got this 94 F150 with a 302. It has recently been giving me some trouble. So it surges at idle and when stopped at a light, struggles to go up small hills and it has been giving me very poor MPG. Additionally, the check engine light will come on for a few seconds but will stay off for the rest of the drive. When the problems first started, my truck died when I was pulling into the driveway too. I just ordered spark plugs, wires, distributor cap/rotor and an 02 Sensor. Gonna be cleaning out the throttle body as well. Is there anything else I should look at? Thanks for the help.
Old 08-04-2014, 11:01 PM
kevin206's Avatar
kevin206
kevin206 is offline
May not be your problem, but I have similar problems and I've masked them by blocking my EGR. Actually, I just pulled the vacuum hose and plugged it, but my EGR seals well. My EGR tube is busted and I am sucking in fresh air instead of exhaust and it's been causing some stumbling due to the leaning out of the fuel mix.
Old 08-04-2014, 11:53 PM
kermmydog's Avatar
kermmydog
kermmydog is offline
Check fuel pressure. When my pumps started to fail it would throw the CEL because lean condition at O2 sensor.
955ohswap
12-12-2014 01:56 AM
wildcat99
07-05-2007 07:18 PM
97FRD1TN
10-08-2006 06:42 AM
JohnPeter
Modular V8 (4.6L, 5.4L)
05-23-2006 02:46 AM
Sanford Owner
03-22-2006 12:31 AM
Quick Reply: 5.0 issues
