Air Conditioner Question
Old 09-01-2014, 03:21 PM
bunky383's Avatar
bunky383
bunky383 is offline
Originally Posted by SirTed
Hi guys,
I just bought '04 E350 with a little over 67k on it. The AC wasn't working at all, so I got a 12oz can of r134 and put it in. Prior to this, the ac clutch wouldn't spin, I got the pressure up to 35lbs and the clutch spun, but then it went back down to zero.
The guys at the parts store say I need 60oz of stuff in the thing to completely recharge it, how do I tell if I have a leak or if the little amount of stuff I put in the system just 'evened out' and I lost all that pressure again?
Yeah 60oz is way too much. Without a set of gauges on it you are just guessing.
Sent from my Z10 using IB AutoGroup
  #32
Old 09-01-2014, 03:30 PM
SirTed's Avatar
SirTed
SirTed is offline
Forgot to mention it has rear air.
  #33
Old 09-01-2014, 03:35 PM
bunky383's Avatar
bunky383
bunky383 is offline
Doesn't matter. That's, what, close to 4 lbs? I don't think I've seen a vehicle that's called for more than 2.5-2.75 lbs. Most are around the 2 lb mark. Check under the hood, it will tell you
  #34
Old 09-01-2014, 06:37 PM
celltech's Avatar
celltech
celltech is offline
Tahoes take 4lbs and the AC is ice cold.
  #35
Old 09-01-2014, 07:39 PM
SirTed's Avatar
SirTed
SirTed is offline
Well, the guy wasn't guessing, he looked it up on the store computer. But my question still is, is it leaking or was 12oz not enough to keep the pressure up?
  #36
Old 09-01-2014, 07:40 PM
bunky383's Avatar
bunky383
bunky383 is offline
I'm thinking if 12oz is enough to engage the compressor, he shouldn't need too much more
  #37
Old 09-01-2014, 07:48 PM
SirTed's Avatar
SirTed
SirTed is offline
12oz did engage it, but not for long. All this happened within about a minute or two of pressuring up.
  #38
Old 09-04-2014, 12:06 PM
Green Gem's Avatar
Green Gem
Green Gem is offline
Lots of information here.
https://www.ford-trucks.com/forums/1...-speak-up.html
I have not succeeded in getting a dealer to repair mine. They barely even look at it under its problem conditions/temperatures.
Good Luck
Green Gem
dnkensinger
08-22-2015 10:28 PM
jdm5630
06-13-2014 11:20 AM
noregrets36
1999 to 2016 Super Duty
04-20-2011 11:06 AM
ttttmaxx
16
05-30-2008 09:58 AM
jeffhead
2004 - 2008 F150
51
08-03-2006 10:11 PM
Quick Reply: Air Conditioner Question
