1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
fuel tank upgrade
Old 08-26-2014, 07:41 PM
985diesel's Avatar
985diesel
985diesel is offline
fuel tank upgrade
Has anyone changed out a fuel tank on a 2011 or newer 6.7. I would like to put a stock 37.5 gal tank in, what all do i need to do. I looked at buying a after market tank but dont want to spend the $$$. About the put the dpf delete on. do that help with space
Old 08-27-2014, 05:07 AM
Just Strokin's Avatar
Just Strokin
Just Strokin is offline
I have replaced my stock 37.5 gal tank in my 2015 CC LB 6.7L with a Titan 65 gal tank. Most of the aftermarket tanks are designed to fit stock location and use straps that bolt to the stock locations. Installing a tank not designed to fit the stock location might cause more problems than worth in the long run. Be safe and bite the bullet to do one time big spend to get a tank designed to fit and avoid a catastrophe down the road if your "hope-it-fits tank" fails.
Desert Dave
2017+ Super Duty
01-24-2019 08:31 AM
bell47man
2014+ Transit
11-12-2015 12:13 AM
MentalState
02-26-2009 06:17 PM
f1001978
1978 - 1996 Big Bronco
03-28-2004 03:14 PM
BTW
10-10-2003 06:19 AM
Quick Reply: fuel tank upgrade
