Anyone use aFe Atlas exhaust?
Looking to go with an aftermarket exhaust - anyone running an aFe ATLAS exhaust?? I like the looks of the joints and clamps.
Anyone have experience mounting both aFe and say MBRP that can provide pros/cons of both systems?
I'm not concerned with each companies muffler sound as I'm straight piping.
Out here in MA we support the salt industry as well...but I undercarriage wash it once a week in the winters so I'm just going to go Al.
I don't really hot-dog it all too much, but as far as the 5-0 is concerned...I've got an in
If the noise gets to be too much a friend of mine has an MBRP muffler that he never mounted that I can use. I'm thinking I may end up going that option seeing how the enclosed rear cab of the Excursion will probably trap some of the resonating from the tail pipe...and ultimately **** off my wife and kids. Gotta try it straight'd first though!
I just bought the aFe 4 in. Mandrel Bent 409 Stainless Steel Tubing cat-back system from Amazon for $348. My son and I installed it in about 2 hours which included removing the original. I did go from a muffler deleted system to using their muffler. Sounds OK as it is a straight flow through muffler. Just not as loud as when deleted.
Thanks BP.
Watson - didn't think about that. I know with welding it's an obvious no-no. But If you're just clamping to together it shouldn't make a big deal. I'll look into it though.
Edit: Ok - just checked and found a page that detailed faster/base metal comparisons which works just as good in this case. Mating stainless with aluminum increases corrosion rates for both metals when in contact. So I will have to find alternate muffler options as I don't see the value in spending the cha-ching for a T304 system right now and the T409 will get just as crappy as the Al in my climate, as I will not be scouring my exhaust every winter.
Last edited by TinMan289; 07-28-2014 at 10:06 AM. Reason: enlightenment discovered
eric777
06-09-2009 09:33 PM
