Rear Axle Spline Count?
Most but not all 1/2 ton 2 wd trucks used 28 spline axles. Really no way to tell without pulling an axle and counting splines. But it only takes about 20 minutes to pull an axle out and replace if you have air tools. I have nothing to back this up that is official but I have worked on alot of Ford trucks over the years and this is strictly my experience speaking.
This is what you'll see when you take the wheel off. The axle retaining nuts are accessed through the hole in the axle flange.
A little tip. If the axle doesn't want to come out, make a poor man's slide hammer. Put the brake drum on the studs backwards. Turn the lug nuts around so the flat side is towards the axle and thread onto the studs by three or four turns. Then use the drum as the slide weight and bang the axle out.
Usually though, the axle comes out without too much trouble.
EDIT: What part of FL are you in?
swampape
03-19-2011 03:11 PM
Sleepy_Dave
09-19-2010 03:57 AM
FrayedSanity
04-12-2003 10:55 AM
DannyP
09-27-2002 06:18 PM
