6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Periodic "No throttle response"
Old 07-24-2014, 12:14 PM
HighOctane's Avatar
HighOctane
HighOctane is offline
PMS: an obsession
Hey all, I have an 08 F-550 with the 6.4L and periodically the throttle seems to crap out and have no response at all. The truck still idles, but there is nothing when depressing the pedal. Turning it off seems to reset it, but it has started doing this in the last couple days only. I realize the throttle is probably a drive by wire system, so is there a module or something that commonly acts up to cause this? Thanks for any help or recommendations in advance.
Old 07-24-2014, 12:29 PM
slowmans's Avatar
slowmans
slowmans is offline
I know the 6.0's had issues with the pedal going dead but I havent seen this to often with the 6.4, I believe the pedal is actually electronicly controlling the throttle..? You may need a new assembly.
Old 07-24-2014, 01:16 PM
BoKnowsDiesel's Avatar
BoKnowsDiesel
BoKnowsDiesel is offline
Former Vendor
Do you have any stored codes? I would think a fault in that system would set some sort of code (like a P1586) but if it's intermittent it might not set the MIL
Old 07-27-2014, 10:17 AM
langballs's Avatar
langballs
langballs is offline
I had a similar problem where my truck would only get a quarter throttle on the pedal. Would be enough throttle to get up to speed on highway but that was it. I have a Mini Maxx tuner so I could check my throttle percentage and it said the pedal was working. Plus my cruise wouldn't work and no codes. I checked my LPFP at home with the key on engine off and it was very noisy. Replaced pump and truck like new again. Just something to check.
Old 07-31-2014, 01:54 PM
HighOctane's Avatar
HighOctane
PMS: an obsession
Apparently, according to the stealership, the EGT sensor is bad, and putting my truck into limp mode. $480 cures the problem I hope.
Old 07-31-2014, 07:29 PM
slowmans's Avatar
slowmans
slowmans is offline
Wow, you can buy that sensor pretty cheap and change it your self!
haledamage
09-21-2016 07:18 PM
Chris611
6.7L Power Stroke Diesel
04-04-2014 09:37 AM
joeyd61
03-05-2013 02:18 PM
kat6770g
10-16-2011 12:46 PM
lexasgs400
18
03-22-2011 07:19 AM
Quick Reply: Periodic "No throttle response"
