missing hose?
You need part number 6B899 to fix that, buying one any place but ford doesn't look good.
<table id="rptrNonCallouts_ctl00_gvNonCallout" cellspacing="0" border="0"><tbody><tr class="gridViewRow"><td style="width:16%;" valign="top"> 6B899
</td><td style="width:26%;" valign="top"> Engine Crankcase Tube T-Connector
7.5L; This tee attaches intake vacuum to the screw in pcv valve
</td><td style="width:10%;" valign="top">$13.48</td></tr></tbody></table>
yea since thats the part number its 4.99 at Oreilly auto but do i also need a hose to go from the bottom of the tee to connect to the port on the engine and do i need clamps too? thanks so much
Be careful with that black plastic tube, small chance it might be brittle. If so you'll wanna replace it but check it out first, the larger lines in my experience don't tend to get brittle near as easy as the little ones do.
At any rate you will want to treat it with care when removing the old tee.
No you do not need a hose, the tee goes directly onto the PCV valve and nope no clamps required.
Probably the reason it broke, you can see in the pictures that tee is cracked and brittle. Someone probably when to check or replace the PCV valve and when they pulled the tee off part of it broke off rather than expand like it should when it was still pliable.
Put a new on on it a minute you should be all set, if not or have more questions just ask, always plenty of good people here willing and ready to offer help.
chuckofthestreet
06-12-2018 06:34 PM
Jay Is Jay
1999 to 2016 Super Duty
05-28-2017 06:02 PM
