what engine do I have????
Old 07-22-2014, 05:03 PM
blick's Avatar
blick
blick is offline
I got a 1980 ford F250 for a donor parts truck. the motor it had aftermarket valvepan covers, intake, and carb installed so I can't tell from the original stickering what it is. The casting number on the block above the starter is D7TE-A-2-E. Can the motor be determined from this?? The trucks VIN number indicates that it originally had a 302 in it, but I don't think it's the factory motor.
Old 07-22-2014, 11:45 PM
fuzzybob's Avatar
fuzzybob
fuzzybob is offline
Hi blick, I believe it's a 351 M 400
Old 07-23-2014, 12:10 AM
85e150's Avatar
85e150
85e150 is online now
Received 1,632 Likes on 1,331 Posts
Count the valve cover bolts.
Old 07-23-2014, 07:20 PM
blick's Avatar
blick
blick is offline
Each valve pan cover has 8 bolts.
Old 07-24-2014, 12:27 AM
85e150's Avatar
85e150
351M/400 has 8 bolts.
351C does also, but the D7... (1977) eliminates that as a possibility.
If it's a 400 it is worth a little more than a 351M. Easier to bring a 400 into line power wise.
The blocks were the same, so the casting number is no help. In fact, nothing external is any help. See here, the first few posts and the final post tell the tale. Short version: Pull the pan.
https://www.ford-trucks.com/forums/1...g-numbers.html
rsalter66
12-16-2007 06:30 PM
ShadowWulf
02-04-2006 09:24 PM
kierstinsdaddy
19
01-11-2006 07:40 PM
rhetor
05-17-2004 08:27 PM
Bill_Beyer
07-06-2001 04:04 PM
Quick Reply: what engine do I have????
