1977 f150 engine swap?
Old Jan 11, 2006 | 07:53 AM
kierstinsdaddy's Avatar
kierstinsdaddy
Post 1977 f150 engine swap?
I just bought a 1977 ford f150 and I was told that the engine had beed changed out , how can I tell for sure and if so how can I tell what engine is in the truck now? any help you can give would be great
Old Jan 11, 2006 | 09:07 AM
KJKozak2's Avatar
KJKozak2
There should be a sticker on the valve cover indicating the engine type (if it's still there and ligible). If not, start by how many cylinders it has (6 or 8). If it's 8, count the valve cover bolts.
You can also enter the vin number on this site: http://www.medicine.wisc.edu/~mrm/bronco/ftvin.cgi and it'll tell you all kinds of stuff including the original engine.
Try searching this forum for more information on engine identification. It's been discussed numerous times.
Kevin K.
Old Jan 11, 2006 | 01:32 PM
Mil1ion's Avatar
Mil1ion
Start with the number of valve cover bolts.
If it has 8,this means it's either a 351M or a 400 ?
To tell the difference between these 2 you will have to physically measure the stroke as externally they are identical.
Old Jan 11, 2006 | 02:17 PM
kierstinsdaddy
yeah it has 8 bolts on the valve cover, i know by the vin that it came with a 302 and I have no idea how to go about measuring the stroke there was no sticker on the valve cover but there is a number stamped on the manifold im not sure if this can tell me anything
Old Jan 11, 2006 | 03:00 PM
Mil1ion's Avatar
Mil1ion
There are a couple of ways.
One is with a rope, the other with a piece of doweling.
With the dowel located in the sparkplug hole into the cylinder ....You basically turn the engine over so the piston goes to the bottom of its travel.
Make a mark on the dowel for lowest point or BDC.
Now turn the engine over so the piston comes to TDC ...mark the dowel.
The difference between the 2 marks is the length of stroke.
4" stroke = 400
3.5?" stroke is a 351M
Maybe Bubba here explains it better.
http://home.earthlink.net/~bubbaf250.../parts110.html
Old Jan 11, 2006 | 03:03 PM
kierstinsdaddy
Question valve cover sticker
I just went out and found a sticker on the valve cover but I dont really understand what the numbers mean any help you can give would be great
here is whats on the sticker as far as I can tell
cbk584aa c60 k
Old Jan 11, 2006 | 03:05 PM
Mil1ion's Avatar
Mil1ion
584 is probably the engine size.
As I said in the other thread, That is plant reference info.
Which valve cover and where on it did you find it ?
Old Jan 11, 2006 | 03:13 PM
kierstinsdaddy
the sticker is on the front end of the passenger side valve cover
Old Jan 11, 2006 | 03:17 PM
Mil1ion's Avatar
Mil1ion
That's the engine calibration code sticker to let you know the values of any tuneup specs and to also explain the proper vacuum hose routing.
It should look like the pic top left hand corner of this page.
http://www.clubfte.com/users/mil1ion...strations.html
Old Jan 11, 2006 | 03:19 PM
Mil1ion's Avatar
Mil1ion
Let me know the numbers where the 80 shows up in the above pic.
I suspect the numbers 77 are there
Plus all the digits that that are just left of the pointed out digits on the pic.
as in the:
C|93
R|0
Old Jan 11, 2006 | 03:33 PM
kierstinsdaddy
ok where the 80 is on the pic there is an 80 on the sticker also as for the pointed out numbers c is 60 and I cannot read the other
Old Jan 11, 2006 | 03:59 PM
kierstinsdaddy
i also found the the numbers
18726848
stamped on the engine
Old Jan 11, 2006 | 04:03 PM
Mil1ion's Avatar
Mil1ion
Those don't mean anything to me.
Can you look for casting numbers that look like this on the block,heads & Intake?
https://www.ford-trucks.com/user_gal...=23691&width=0
Old Jan 11, 2006 | 04:48 PM
kierstinsdaddy
i looked but i think i need to clean up about 30yrs of grime to get to the stamps
Old Jan 11, 2006 | 04:52 PM
ford390gashog's Avatar
ford390gashog
could also be a 351c
