ABS light
Old 07-21-2014, 10:44 PM
elymashburn's Avatar
elymashburn
elymashburn is offline
ABS light
I have an 03 F150 supercrew FX4 and I noticed today that my ABS light has came on and won't go off. I know I need to replace the front pads and rotors, but what will cause the light to come on?
Old 07-22-2014, 06:51 AM
projectSHO89's Avatar
projectSHO89
projectSHO89 is offline
A fault in the ABS system will turn on the ABS light.
Check the rear differential sensor, it's the most common failure.
Old 07-22-2014, 06:16 PM
Dr. Dirt's Avatar
Dr. Dirt
Dr. Dirt is offline
the light can come on if any of the sensors have a fault in them. a bad enough wheel bearing can cause an ABS light. a problem with the module itself. if you have a scanner that reads ABS codes look at the codes and see what wheel it says that way you can at least have a starting point.
Trevor.801
01-10-2015 04:55 PM
jhg_12
1978 - 1996 Big Bronco
04-22-2013 03:55 AM
Trevor1
08-22-2006 05:01 PM
Quick Reply: ABS light
