Sponsored by: Auxito
Question About Towing Plug
Old Jul 21, 2014 | 04:27 PM
qman's Avatar
qman
I have a buddy that has a 1997 F150. He says that his trailer plug was spliced (hacked) straight in to the truck's harness and whoever did it did a crappy job and cut the wires about 1/8 inch from the harness plug. When I mentioned that he should put in a T-connector he said that he's been told by part stores that nobody makes them.
I find that hard to believe. Can someone verify this for me?
Old Jul 21, 2014 | 05:45 PM
Bluegrass 7's Avatar
Bluegrass 7
Lets first see if he is talking about a 4 lead connector or a 7 lead and intended trailer size if electric brakes are required..
Then, he needs to know that trailer connectors use is a separate function for power from the fuse protection point.
This separate power source is to prevent loss of lighting on the truck should a short occur on a trailer.
He cannot just tap into the directional and light leads and expect not to upset flasher timing and power loading on existing circuits.
The proper way is to install the correct harness for trailer towing and put in the relay and fuses required.
Otherwise it is just a hack job with no reliability for either the truck or trailer.
Likely not what he want's to hear but this is the proper way for the reasons above.
Good luck.
Old Jul 22, 2014 | 02:58 PM
qman's Avatar
qman
I already told you it was a hack job.
My question is, can you buy a plug that just t-plugs straight into the truck's harness without having to hack wires?
Old Jul 22, 2014 | 07:13 PM
Bluegrass 7
NO. I already told you why!
I would just be an extension of the hack job.
Good luck.
Old Jul 23, 2014 | 06:08 AM
niner's Avatar
niner
qman, if you are asking if there was a T-connector harness that could have been installed prior to the hackjob (or after, if he puts the wiring back to factory), then the answer is yes - it is this one:
Tow Ready Custom Fit Vehicle Wiring for Ford F-150 and F-250 Light Duty 1997 - 118242
I just installed one in my '03 F-150. The connector is pretty far forward - ahead of the spare tire, and about 1 1/2" x 1 1/2", in one of the rails. I did need to use the two relays, but the truck was already fused - which is good, since the fuses were the wrong style (my truck takes the square-ish maxi fuses).
Old Jul 23, 2014 | 09:49 AM
qman's Avatar
qman
So the answer is YES!
Thanks niner. That was all I was asking.
crucialprospect
17
Mar 31, 2018 03:57 PM
DetailerDave
All Things Towing
28
Sep 18, 2013 01:09 PM
lloydmiiller
1997 - 2003 F150
Sep 19, 2011 04:20 PM
SuperDutyScaler
Sep 20, 2010 02:14 PM
j4rdemotox
Modular V10 (6.8l)
Jan 11, 2005 01:00 PM
