cost of 4spd swap?
cost of 4spd swap?
what would be a fair price to pay at a junk yard for all the parts need to swap a c6 to a 4sp?
im talking pressure plate, clutch, bell housing, trans, maybe trans case, clutch pedels and linkage, cross member, maybe drive shafts (il have to measure them) and maybe steering colom.
Missing from the list above: Flywheel, pilot bushing/bearing, trans tunnel cover, starter, and trans inspection cover.
Depends! But I figure a ballpark number is around $600 to $800. Do it once and do it right so buy a replacement clutch disc, pressure plate, and throw out bearing.
Some yards have standardized prices... many don't and seem to gouge pickers because they have them bent over a barrel and "need" the part. I like places like Pick N Pull (a division of Schnitzer Steel) because I absolutely know what I am going to pay. Well, except for odd parts like a light bar off a tow truck ($40!).
Example... PNP in Cumberland, Rhode Island: Pick-n-Pull » Part Pricing
I did the auto to manual swap for about $300. I paid $150 for every piece i needed from a junkyard that was going out of business. I bought a new clutch kit and had the flywheel resurfaced. I did have to have the rear driveshaft lengthened. You may also consider buying a complete truck for the swap since i have seen alot of complete trucks for cheap in my area
To the OP: Do some research on 335 family starter variations.
The shafts were different on my 79 bronco when i did the swap since the 4speed was shorter then the C6, but only a couple inches different. A 77.5-79 f250 engine/trans is the same as a 78-79 bronco and they both use high pinion diffs so its basically identical. I did the swap al long time ago so details are fuzzy but i did have to modify the shafts
I just converted mine, bought a 4wd parts truck for $1000. Swapped the C6 for a 435. I ended up using a lot more off the parts truck than I thought I would, grill, tail lights, mirrors, all kinds of misc clips that were broke. Had to have a drive shaft made. Only bummer is the speedo cable goes to the transfer case and converting to 4wd is way down the road.
wstuckey1
15
07-11-2019 07:34 AM
boggin79ford
10-11-2012 10:45 PM
Bryce Heinz
01-22-2010 10:00 AM
turbo2256
26
04-25-2004 11:15 PM
