bolt question
Old 07-18-2014, 09:08 PM
newguy399's Avatar
newguy399
newguy399 is offline
bolt question
hey guys, I putting the cab on the frame and I think the bolt is to short for the front cab mount. I bought the mid fitty cab mounting kit, the bolt is 3" long. anyone have pictures, thanks in advance.
Old 07-19-2014, 02:59 AM
underthebridgejim's Avatar
underthebridgejim
underthebridgejim is offline
FTE fan
I normally would not try to answer a question that Im not familiar with, but after seeing no responses as of yet, I did my best to find a schematic of your front cab mounts, which I did and posted it below, however I do not have the text that goes along with it to ID any part. I'm sure if you post which bolt you are talking about , someone with the accompanying text, will be happy to ID the proper bolt length, threads, etc. Sorry, I know this does not answer your question, but at least you can now ID the bolt by part #.. that you are referring to.
Old 07-19-2014, 07:06 AM
Harrier's Avatar
Harrier
Harrier is offline
I tried to look through the text catalog to find the bolt but couldn't. Normally you have a major part to reference. The rear mount is in section 53 (5360) so and it has the bolts there. But this one doesn't have that.
That really bugs me. Hopefully someone that knows what their doing will tell us.
On a side note, did you notice their specifications for the rubber parts on the front mount? "Improvise from tire carcass or similar material" I wonder how they did it in the factory?
Old 07-19-2014, 07:32 AM
teardropty's Avatar
teardropty
teardropty is offline
If memory serves me correct, I had to use a 5" bolt from the local hardware to get things lined up and snugged down. Once everything was tightened down, I was able to go back and remove the longer bolt and replace with the shorter bolt. The rubbers stay expanded until they are snugged down. There is also nothing wrong with leaving the longer bolt in place just make sure it is a grade 5 or higher. Enjoy, cab mounts take some fiddling.
Old 07-19-2014, 08:04 AM
newguy399's Avatar
newguy399
thanks for the replys , when putting it together does the top cup that goes between the frame number 00134. does it sit in the chanel under the cab or does does the cab sit on top of it
Old 07-19-2014, 05:00 PM
teardropty's Avatar
teardropty
New cup and rubber installed on a 54.
Old 07-19-2014, 05:33 PM
Harrier's Avatar
Harrier
Harrier is offline
Where here is how I see it. I'm far from an expert though and these are pictures of the original parts.
Page 110 of the mid fifty catalog seems to show things well.
http://midfifty.com/images/2014_half...Catalog_sm.pdf
The rubber looks to be gone from the cup, which after 60 years is to be expected.
Just to show the original bolt was ~3 inches.
Old 07-20-2014, 11:16 AM
newguy399's Avatar
newguy399
Thank you for all the help,that was the picture I was looking for something just didn't seem right,
514 ford stomper
1997 - 2003 F150
08-03-2008 08:30 AM
crazyredneckanyhow
09-23-2007 06:50 PM
T-B_MN
2004 - 2008 F150
07-19-2007 04:11 PM
rboeding
01-31-2006 09:42 PM
SReiman
1983 - 2012 Ranger & B-Series
01-24-2004 08:24 PM
Quick Reply: bolt question
