Periodic "No throttle response"
Hey all, I have an 08 F-550 with the 6.4L and periodically the throttle seems to crap out and have no response at all. The truck still idles, but there is nothing when depressing the pedal. Turning it off seems to reset it, but it has started doing this in the last couple days only. I realize the throttle is probably a drive by wire system, so is there a module or something that commonly acts up to cause this? Thanks for any help or recommendations in advance.
I had a similar problem where my truck would only get a quarter throttle on the pedal. Would be enough throttle to get up to speed on highway but that was it. I have a Mini Maxx tuner so I could check my throttle percentage and it said the pedal was working. Plus my cruise wouldn't work and no codes. I checked my LPFP at home with the key on engine off and it was very noisy. Replaced pump and truck like new again. Just something to check.
lexasgs400
18
03-22-2011 07:19 AM
