Ideas for broken injector cup still in head removal?
#46
#47
Since this more common in Alaska, I'd look at the operation of the vehicle:
What if a dead-cold engine with an exhaust/boost leak gets a hard run? Could the temperature shock stress that part of the cup?
- Vehicle left idling while shopping.
- Plugged in for most of the year.
- Thermostat rarely needs to open, compared to the lower 48.
- Extreme temps.
#48
Just a little update, I was able to get #2 out using air chisel to knock a cross and then fold the edge over, wasn't nearly as lucky with #4 as I nicked the side of the bore pretty good, so I ended up swapping heads anyway.
Thanks for all the ideas and thoughts though, I appreciated and considered all of them. New cups, and a different head all in, and truck is running good again.
#52
This is old, but for anyone coming across this thread, would it have been possible to use a soldering iron to braze a little extra material to the inside of the cup? If so, the extra material would constrict when it cooled. Add enough material and it would pop it free. At least that is how I remove outer races when I swap out hub bearings.
7.3 forever
59
09-21-2017 12:43 PM
Jaaaaaaackman
10-08-2007 08:59 AM
palmercomputes
15
12-27-2006 11:36 PM
palmercomputes
12-09-2006 06:07 PM
