Guess what COOL new item Alliant Power has for us
AP0040 aka Injector side plug!
Read here.
http://alliantpower.com/sites/allian...a_04-14_en.pdf
here is the tech sheet with the how to.
http://alliantpower.com/sites/allian...b_03-14_en.pdf
Now to find who stocks them and how much.
Sean
Read here.
Sean
Good find. I've been working with my part guy for the last week trying to find this again. I knew I have seen it before in a catalog we had at the shop but couldn't find it. Hopefully will have some sitting on the selves at the shop pretty soon.
Sending some reps your way
Edit....starch that. Will send some reps after I spread the love.
I would think that is would also be chemical dependent.You need
something that is aggressive enough to dissolve or soften the varnish
so that the c=action of the ultrasonic bath can carry it away. That is
the tricky part finding something that will do that and not go BOOM in
the cleaner tank with a bit of heat. Also it has to be something that is
safe to use unlike the old school vapor degreaser agent that did all
sorts of nasty things to the body. If I recall the EPA made them have
a babysitter for it 24/7 so it would not spill or something else.
Sean
Sean
Cool find Sean! You may want to consider something like this for the splices.
HEAT-SHRINK BUTT SPLICES from Aircraft Spruce
Or solder and this.
http://www.aircraftspruce.com/catalo...heatshrink.php
Or solder and this.
Or solder and this.
Or solder and this.
Sent from my Telegraph using IB AutoGroup
