4.9L to 5.8L
4.9L to 5.8L
I wanted to swap my '91 4.9L L6 for a '91 5.8L v8, so I just recently bought a '91 5.8L v8 with a dual exhaust setup, and the 5.8 ECU.
What are all of my obstacles and what is absolutely necessary to get the truck running and what is advised? Will the old wiring harness work? Do I only need to buy one motor mount?
I have an E4OD transmission.
on
Did you buy a donor truck or just the engine?
You will need V8 frame towers and engine mounts and the I6 versions have to come off, you need a complete 5.8EFI motor from oilpan to throttlebody and including accessory brackets, a complete V8 engine harness, a 5.8/E4OD PCM, a 5.8 specific flexplate(28oz imbalance), and a V8 rad and hoses.
On the engine frame towers, the I6 ones will unbolt from the cross member. The V8's have 2 or 3 rivets on the driver's side you will have to remove and replace with grade 8 bolts and nuts.
Also to make live much easier with a swap, try to get the entire engine bay harness too. Best to get the same year as your truck, then it will be plug and play with the firewall bulkhead electrical connector.
I done the opposite of what you are going to do. I replaced a blown 302 with a fresh rebuilt I6. Trying to use a 92 engine harness with a 89 electrical system, took me a week to repin/resplice to get it running!
I have a 1991 f-150 custom with a 4.9 L6 (original motor), and I bought a 351/5.8L to swap it with the 300. The engine I bought is a complete assembly valve cover to exhaust manifold.
I currently have in possesion: 5.8 ECU, Summit Dual catback exhaust for 91 f150, Magnaflow Direct Fit Cat for 5.8, 5.8 engine assembly
I wasn't sure on the mounts, harness, rad/hoses, flexplate, old accessories, etc.
Sorry for the lack of information given, but I just want to make sure I have everything I need before I start this job.
I just bought a radiator, rad hoses, a/c and p/s brackets, flexplate, and mounts.
So for the swap, I have:
- 1991 EFI 5.8L V8 Engine Assembly
- 5.8 ECU
- Summit Dual Exhaust Catback System
- Direct Fit Magnaflow Cat
- 2 core aluminum radiator for 5.8 V8
- rad hoses (upper and lower)
- 5.8 Engine Mounts
- 5.8 flexplate
- 5.8 power steering and a/c brackets
Hopefully I will be able to make everything else work, but with the mounts and flexplate I should at least be able to make it driveable (not that being the goal, I will immediately purchase anything that needs to be purchased to make it right).
Have an e4od that I plan on keeping, maybe just change the fluid and filter on it. Going to do the same with my rear diff.
Any pointers are highly appreciated.
- 5.8 ECU
- 5.8 Engine Mounts
- 5.8 flexplate
WestTexasF150
02-02-2016 12:29 PM
Jeremy DeMedeiros
55
02-26-2012 09:25 PM
ironmanisanemic
02-18-2011 12:12 AM
