7.3 Bad injector
Old 07-08-2014, 05:46 PM
Smokey_7.3's Avatar
Smokey_7.3
Smokey_7.3 is offline
7.3 Bad injector
You guys are awesome! I can't thank yall enough for the help I've received here.
But onto the next challenge!!!!
My 96 7.3l has a dead cylinder. Scanner says cylinder 5. What all is required and is there a good write up on how to replace the injector myself?
Old 07-08-2014, 08:46 PM
ReBilld's Avatar
ReBilld
ReBilld is offline
May not be the injector. Could be the wiring to that injector. Check the plug on the valve cover gasket for burnt pins.
Old 07-08-2014, 10:25 PM
Smokey_7.3's Avatar
Smokey_7.3
Well I have a set of 8 OEM injectors and a different gasket I have laying around. Took me a little while to figure out how it all came our but it's done.
She's still puffing like a chain smoker but runs smoother.
Old 07-08-2014, 11:27 PM
MOOSE_MACHINE's Avatar
MOOSE_MACHINE
MOOSE_MACHINE is offline
Originally Posted by Smokey_7.3
Well I have a set of 8 OEM injectors and a different gasket I have laying around. Took me a little while to figure out how it all came our but it's done. She's still puffing like a chain smoker but runs smoother.
Puffing what color. I'm assuming you pulled the injectors but did you replace the orings.
Old 07-08-2014, 11:43 PM
Smokey_7.3's Avatar
Smokey_7.3
Blue.
Yes I did replace the orings on that 1 injector I replaced. I didn't swap all 8.
Old 07-09-2014, 07:49 AM
oldbird1965's Avatar
oldbird1965
oldbird1965 is offline
Blue should disappear, its probably oil left over in the cylinders from the injector being changed out.
Old 08-22-2014, 03:58 PM
Smokey_7.3's Avatar
Smokey_7.3
Turns out it was a bent connecting rod. Replaced and smoke went away. Thanks you guy!
Fordx4jake
11-03-2014 07:51 PM
FordOwnerJoey
06-26-2014 07:57 PM
johnboggs21
04-23-2011 11:27 AM
jdb111485
08-03-2010 11:48 AM
Winmilcook
10-12-2006 12:36 PM
Quick Reply: 7.3 Bad injector
