Gauge Cluster from 1991 F-150
Old 07-02-2014, 03:24 AM
49f2owner's Avatar
49f2owner
49f2owner is offline
Can a gauge cluster from a Ford 1991 f-150 be wired directly instead of using the exacting method which has a cluster that has a strip with several large connection that go in the back I wanted to use some the gauges in my original cluster for the 49..
Jim
Old 07-02-2014, 04:14 AM
big job's Avatar
big job
big job is online now
I suppose so, using the F150 senders. You do know these gauges plug in
the cluster. Then figure out the plus & sender prongs. Less work using
1973 thru 79 gauges and senders. the 91's & up are a different animal unlike
the bimetal king seely's..
Old 07-03-2014, 02:05 AM
49f2owner's Avatar
49f2owner
Yes I do know that they plug into the cluster I suppose I can figure out which wire goes where and go from there. The problem is that the cluster won't fit in the 49 dash cluster. I will work on trying to make it work I have a service manual for the 1991 will have to run down what wire goes where..
Thanks for help.
Jim
Old 07-06-2014, 10:08 PM
tip49's Avatar
tip49
tip49 is offline
https://www.ford-trucks.com/user_gal...239435&width=1 this picture was my original setup using Ford gauges and speedometer.
I am using late '80's gauges in my F1 instrument cluster. Today I inserted a new speedometer into the instrument cluster, the old one quit working so I used an after market Autometer that matches the gauges. The challenge is getting the gauges to match the senders, I haven't got there yet, my 90 Crown Vic had pressure and temperature gauges and idiot lights so I am still needing to "calibrate them to the gauges.
Its all do-able but will need to use resistors to match the senders. You need to remove the gauges from the circuit board instrument panel of your donor, they should mount in your instrument cluster with little modification.
Tom
Old 07-07-2014, 12:28 AM
49f2owner's Avatar
49f2owner
Tom
Now that's what I'm talking about. I have the motor and all the wiring harness and computer ect. that was in the 1991 F-150 so that's why I was wonder if the gauges could be wired directly and not have to use the connection in the original cluster. I don't now what the thing on the back of the cluster is called. I just want to bypass it and connect it directly to the gauges so that I could fit the gauges just like you have in your picture.
Was your cluster similar to the 1991 cluster ???
Jim
Old 07-07-2014, 09:26 PM
tip49's Avatar
tip49
tip49 is offline
1990 Crown Vic Instrument cluster
The crown vic was moulted plastic with a printed circuit board wiring harness, that the wiring harness plugged into. I removed the gauges, had to trim the gauge faces to fit and mounted them into my 1950 instrument cluster, had to use standoff bracket for the ammeter as it was deeper than the others. Late '80's Econoline van and F150 gauges are similar as well, with plastic gauge faces. I got a wiring diagram from the library to sort out the wiring harness. I am using a column mounted turn signal assembly so a lot of the wiring to the CV instruments were eliminated, anti -slosh indicator, seat belt warning light, etc, etc.
I can take a picture of the original cluster from the CV when I am back from work in 2 weeks.
Tom
https://www.ford-trucks.com/user_gal...258758&width=1
Old 07-07-2014, 09:49 PM
tip49's Avatar
tip49
tip49 is offline
More gauge picsposted more pics in my gallery:
Take a look here for a few more pics:
Ford Truck Enthusiasts User Gallery
Old 07-07-2014, 09:52 PM
49f2owner's Avatar
49f2owner
Tom
So would the 1991 have basically have the same printed circuit board as the CV if so than it should work. I have a Haynes repair manual for the 1991 and also the steering whell as it has cruise control so I got that 2. I am going to use the fire wall on the 1991 so I can use the power assisit and the steering wheel.
Old 07-07-2014, 10:01 PM
tip49's Avatar
tip49
tip49 is offline
wiring
I think the wiring colors would be the same for 1990 and 1991; if you are using the wiring harness then the gauge wiring should be similar: yel-white for fuel, red-white for temp and white-red for oil pressure ? using your F1 cluster you will feed power to the first gauge, then the jumper bars on the back will feed power to the other gauges. There is a picture the back of wiring on my current instrument cluster in my gallery.
Old 07-07-2014, 10:33 PM
49f2owner's Avatar
49f2owner
I got it, but I had planed on using the cluster from the 1991 in the 49 so as to have a more modern gauge set in it so that all the gauge read as they should and not get any false readings.
Jim
Thundar76
03-11-2014 09:13 PM
JUSTICE1736
11-09-2012 09:34 PM
psquare7575
02-05-2008 04:25 PM
tacson
12-31-2003 03:39 AM
Quick Reply: Gauge Cluster from 1991 F-150
