Ball stud
Hi Art, , If I understand correctly, your original question was just about how to change the ball stud on the steering spindle arm, which has already been covered pretty well. I also understand that your steering box is good. If this is all correct I would add that there are a couple other wear points that you may, or may not know about checking for wear. They are the pitman arm (ball), which you just replace (on my truck), the drag link which can be rebuilt, the tie rod ends, which are easily replaced, and the front spring pins and bushings. Toe in and caster are adjustments that can also effect steering. You have been on FTE longer than me, so I sure don't assume that you are unaware of these items, and sure don't mean to offend, but I thought it worth mentioning, incase you didn't.
fishjosh
18
07-16-2018 03:21 PM
tonygray
09-23-2007 05:30 PM
Bikewrench
16
06-03-2006 09:15 AM
cbfomoco
10-04-2005 05:30 PM
ddurant
05-22-2003 07:20 AM
