56 F-100 door latch lubrication
I replaced my wore out door latch and striker with new ones from Mid-50. Is the door latch mechanism supposed to be lubricated? Reason I am asking was it was working pretty good when I initially installed it (driver side door latch). Then I thought maybe I should lube up the working parts of it, so I put some Lubriplate white grease on the inside star gear and paw assembly and the out side rotor. Now sometimes the door wants to bounce back out on the 2nd click. The Ford shop manual tells you to lube the parts with a special lubricant, and it gives a C4 part number. You probably can't find that today anywhere. Anyway it got my thinking to ask what other people have used, or if it's even necessary.
I would never use a a grease or oil on latches and things that are exposed and not sealed. Many manufactures also do not recommend it as it collects dirt which causes wear and cause them to not move freely. I highly recommend graphite. That is what they use on locks for the very reasons I mentioned. For door latches and automotive use I recommend the spray graphite. It has a liquid that carries the graphite into the mechanism and the liquid evaporates leaving the dry graphite film behind.
P.S. Where in Iowa you from, I am from Le Mars in the NW corner.
Truckteemford, that is interesting about the graphite spray. Good to know.
Graphite will wash away so does not add water resistance, needs to be reapplied. I figure if a latch or hinge has lasted 5 or 6 decades greased from the factory and likely never again, using a high quality grease like white lithium (lubriplate) or moly based will not collect or transfer much dirt, will resist rusting (the real killer), and with the minimal movement involved they should last a lot longer than I will.
