need help
Old 07-04-2014, 06:19 PM
nicknault's Avatar
nicknault
nicknault is offline
need help
Hey guys i just did a spark plug and oil change on my 96 f150. It has a 4.9 straight six in it. The truck ran fine before i did the spark plug and oil changes, and now it wont start. All plugs are gapped to .044 and no fuses are blown. All other electronics work and it turns over fine. I also checked the distributor and wires. All is good. If anyone can help that would be great.
Thanks, nick
Old 07-04-2014, 06:51 PM
cstephens's Avatar
cstephens
cstephens is offline
Thanks, nick
Something happened in that time. Pull one spark plug and lay it on the engine block. Have someone crank it, see if it is sparking. Might not have put the plug wires back on right. The proper order of the plugs is 1-5-3-6-2-4.
If it is sparking, then you have 1 of 3 things needed for a running engine. Fuel, fire, and air.
Make sure there is gas in the thing. Thats happened to me before.
Check to make sure the filter/air duct arent obstructed by anything.
Also check all connections on the fuel system. Mightve pulled something loose trying to get to the plugs.
Just some stuff off my head. Someone else will be along to give further help, Im sure.
Old 07-07-2014, 10:27 AM
AbandonedBronco's Avatar
AbandonedBronco
AbandonedBronco is offline
Another thing I've found that works really well for this is jumper cables. Clip one end to the frame and the other around the plug. Makes for a really solid connection, and easier to look at the plug.
Old 07-08-2014, 12:48 AM
cstephens's Avatar
cstephens
I had forgot that! You said that to me on another forum thread, I dont think I really took note of it then, but I really like that chicken nugget of advice. Beats HOLDING THE PLUG WIRE like I tried to do when I was 11. Dad let me too. What I get for being a know-it-all...
Old 07-09-2014, 02:58 PM
AbandonedBronco
LOL, the shock from a spark plug wire isn't something you forget. It won't hurt you, but it will definitely give you the heebie jeebies for a few minutes after.
Old 07-09-2014, 04:48 PM
Harte3's Avatar
Harte3
Harte3 is offline
Ignition shock and electric fence shock are something to behold
Roller150
06-20-2011 12:33 PM
DarrellJ
12-23-2010 02:42 PM
guitar_god2003
Modular V8 (4.6L, 5.4L)
03-14-2010 09:26 AM
SSCX2
General Automotive Discussion
05-22-2006 04:35 PM
fattmann
01-01-2006 07:40 PM
Quick Reply: need help
