Fan clutch bolts
Old 07-03-2014, 06:53 PM
steve340's Avatar
steve340
steve340 is offline
Fan clutch bolts
I need to know what type of bolts are used on the fan clutch for a 1968 390. There is 4 bolts needed for the fan blade to fan clutch mounting and 4 bolts needed for the fan clutch to water pump mounting. I would like the correct style bolt, washer, and color.
Also, what bolts are used on the fan shroud?
Old 07-04-2014, 12:07 AM
orich's Avatar
orich
orich is offline
Geez the water pump flange is like 5/16" X 24 x 1"
Fan clutch hub I believe are 5/16 x18 3/4"
Now this should be check for fitment first but I'm sure you could find some test bolts at the auto parts or Lowes
Orich
Old 07-05-2014, 08:23 PM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
377937-S .. Bolt-Fan Clutch to Water Pump ~ 5/16" -24 x 1"
1968/69 F100/350.
Old 07-06-2014, 11:54 AM
steve340's Avatar
steve340
steve340 is offline
Thank you!
Bill in Bama
WTB - Parts & other
12-09-2015 09:14 AM
cutlass
07-15-2012 11:16 AM
Galendor
07-16-2011 04:42 PM
MadMedic20
04-10-2005 01:27 PM
RKW
08-06-2004 10:56 AM
Quick Reply: Fan clutch bolts
