How can i make my 7.3l idi faster?
Hey guys just curious to know of some not super expensive things I can do to my 93 F-250 7.3 idi 5 speed turbo. I know I need injectors and it has 3.55 gears on an open diff and I do plan to do new injectors and put 4.10s and a posi in it, but other than a banks sidewinder kit what can I do for some more power?
on
no............................no they don't do that.
first things i would do with a factory turbo '93:
idi tune up (injectors/ip/engine timing) replace the crushed downpipe (requires smashing in the cab seam) and installing the banks dp made for the factory turbo and ditch the oem muffler for a BTM (big truck muffler.)
that'll wake her up a touch (or a crap load depending on how long it's been run on worn parts) for under a grand.
Also, keep the 3.55 gears; going to 4.10s makes for hard highway cruising. If you've got a manual transmission, you will be compensating for the gears anyway(using a lower gear longer), or if you have an E4OD, as long as it came stock with the 3.55s, the shift points should be right for that.
As far as waking it up... just what others have told you: A new IP, new injectors and a good timing job is priceless. Then, add some head studs and increase the air(boost) you have. Add more fuel to compensate. Add an intercooler.
It really depends on how much you intend to spend as to how much you will get out of it. 250HP is totally reasonable for a decent tuneup job and fixing the downpipe; that's what Banks says that their kit can do... and the stock turbo itself isn't that much different.
Beyond that, you're talking some money, one way or another.
