1951 F-1 rear axle swap snafu
I've done some research mainly reading (https://www.ford-trucks.com/articles/1948-through-1960-ford-f-1-and-f-100-rear-axle-differential-swaps/) this artical which was full of great info. I found a ford 9" with the right measurement of (close to) 61" from plate to plate with 3½" axle tubes from a friend for the smoking price of a case of beer. Once I got it home I set it on the rear axle and something instantly looked wrong
So I decided to measure the axle that's already installed and came up with this.
The axle that's in it right now is the correct Dana 44 but could it possibly be a from a different car/truck? The artical said it should be the same as the ford 9" I bought? I'm at a loss any help will be appreciated!
I don't have it mounted in there yet, still sitting on the floor.
It measures 59 1/2" wide at the axle flanges where the wheels mount. The axle tubes are 3 1/4" diameter.
BTW on the Explorer they come with a 31 spline axle. There's a lot of info on these axles on the internet, and they're a pretty popular upgrade for the Jeep crowd.
They're not as strong as the Ford 9" of course, but they're considered to be about equivalent strength to Chevy 12 bolt.
Econoline, Bronco and Passenger Car 9's have Right/Left specific axleshafts.
OP: What is the spline count of the axleshafts, what is the size of the brake shoes?
9" from an F100 has the same Right/Left axleshafts. 1957/67 is one type (28 spline), 1968/72 is another (28 or 31 spline-depending on if a 9" w/a 9 3/8" ring gear).
The housing is all I picked up. I had planned to build one of the 3rd members I have rolling around the spare parts bin and just buy a disk brake kit aftermarket.
Dano78
27
04-17-2011 04:08 AM
