Slight delay going into reverse from drive
Hi all,
Today I noticed that our 5R110 was delaying slightly when shifting from drive to reverse. It was probably about a 1-2 second delay but it replicated itself twice in a row. There was no delay going from reverse to drive. It is just an engagement delay. We are running a Superchips Heavy Tow tune on the truck, it is a 2006 6.0 Powerstroke. Has anybody encountered this before?
Thanks!
Thanks!
A normal engagement is 1-2 seconds. If yours is taking longer than that it isn't quite right. Disconnecting the batteries and letting it relearn the parameters it needs MIGHT help.
If your fluid has at least 30k miles, new fluid will probably help. It could also be a solenoid starting to get sticky. Sometimes new fluid will clear that up, sometimes it takes a new solenoid.
JF5speed
05-25-2005 06:12 PM
