212 code, but no TFI module? Does a 7.5L have a TFI?
Old 06-18-2014, 01:30 AM
7.5GasHog's Avatar
7.5GasHog
7.5GasHog is offline
I guess I posted in the wrong forum, so this is kind of a re-post since I didn't get any replies.
So I had a check engine light and 2 codes. First was a 332 code, and I fixed that with a new EGR valve. The light was reset and does not come on but when I check the codes I still have a 212 code. So I figured someone had accidentally put a grey TFI module, when I needed black or vice versa. This is an E350 7.5L 1994, and when I pulled off the air cleaner box to get a look at the distributer, it has the flat part where the TFI mounts, but no TFI.
so 2 questions,
Were the 7.5L's made without TFI's?
I feel as though the code has been there all the time, I do not have any driveability issues, and the check engine light is no longer on, so does this really need to be fixed?
Old 06-19-2014, 05:30 PM
DIYiT's Avatar
DIYiT
DIYiT is offline
Nope. All of the EFI 460s have a TFI module. I think it switched with the body style in 92, but the later trucks are mounted on the driver's side fender on a heat sink. Look right below the hood spring. Check the functionality of the PIP sensor while you're at it. I don't remember if I had the same 212 code, but I had a code pointing to the TFI module as well and it turned out to be the PIP sensor instead.
Rangerforever
1999 to 2016 Super Duty
10-05-2018 04:03 PM
7.5GasHog
06-19-2014 09:42 PM
swampcritter
08-01-2012 10:46 PM
whybnormal
11-22-2007 06:37 AM
scouterspokane
09-07-2005 11:01 AM
Quick Reply: 212 code, but no TFI module? Does a 7.5L have a TFI?
