cab swap
Old 06-05-2014, 06:26 PM
joshua1975's Avatar
joshua1975
joshua1975 is offline
cab swap
Will the cab from a 1969 f100 long bed fit a 1969 f100 short bed? I know the beds will not interchange , but will the cabs. Thanks
Old 06-05-2014, 06:58 PM
JEFFFAFA's Avatar
JEFFFAFA
JEFFFAFA is offline
Welcome to FTE!
Yep there newbie,it will. The cab don't know how long the bed is behind it.
Old 06-06-2014, 12:49 AM
joshua1975's Avatar
joshua1975
Thanks much, I thought so.
Old 06-06-2014, 05:08 AM
jowilker's Avatar
jowilker
jowilker is offline
joshua1975 Welcome to and the Bumpside Forum.
As Jeff noted makes no difference in the trailing bed but the 67-72 trucks share the raised ridge known as Bumpside and will swap.
Don't know why you are wanting make the swap, but want to offer a tip. if you pull the cab & front clip together (front fenders) including doors you can save a lot of time and aggravation with re-alignment. There are 6 mount points to the chassis, 4 under the cab and 2 under the radiator support. You can lift the sheet metal and roll the chassis out or lift it with a machine like a backhoe.
Something to chew on.
John
Mud-and-Guts
19
08-08-2015 06:36 AM
whitenight2
07-31-2012 06:55 AM
tyler70f250
03-18-2011 05:08 PM
wrecker1975
02-01-2006 07:59 PM
CoachRobb
02-13-2004 05:35 AM
Quick Reply: cab swap
