1994 F250 7.3 IDI (non turbo) stalling after about 5 minutes
My 1994 F250 7.3 IDI (non turbo) stalls about about 5 minutes. It idles smooth and fires right up when I first crack it. When it stalls the RPM's dip once or twice and then it stalls. When I crack it back up I have to pat the accelerator vigorously and about about 30 seconds it'll fire right up as if nothing ever happened. I'm new to diesels but I changed the fuel filter and fuel heater about 150 miles ago. Any ideas?
What's your tank level at? It's pretty common for the pickup tube to fall off in the tank. Usually it will give people fits down near 1/4 tank. Otherwise I would check your lift pump, it may have a crack in the diaphragm. Is there diesel in the oil? Return lines and air in the system would not be the cause if it fires up and idles fine for a period of time.
BobbSwitzer
08-10-2012 08:53 PM
jgrzebin
11-28-2011 10:34 AM
