Not getting oil to all rockers
Vehicle is a 1969 f100 with 300. 300 has casting numbers, I believe dates it as a 1966 block.
Heard ticking coming from motor, so I pulled valve cover. Saw that #1 exhuast rocker, #2 intake & exhuast and #3 exhuast rocker were not getting oil.
What I have done so far:
Pulled the rockers and push rods to check for clogs and they were clear.
Pulled oil pan and found a little slug, not much.
Change the oil pump since I was already in the pan, didn't change anything no oil to the same rockers.
Not sure where else to look for clogs, asking for any ideas.
I'm certainly not a subject matter expert...but is your oil pressure normal? See if you cant get your hands on a mechanical gauge and take a good reading. Clogged oil pickups, or a worn oil pump can cause pressure issues (with or without blockages.) If theres a ticking coming from the engine, you can use a mechanics stethescope to narrow down exactly where the noise is coming from so you can narrow down your focus. I have used lengths of garden hose before as well...works in a pinch. Are there any other abnormalities with the engine or how it runs? I'll look in my shop manual and see if i can find some other troubleshooting steps as well.
From shop manual:
When the hyd lifter is on its base circle of the cam lobe, the oil hole in the hyd lifter is indexed with the oil gallery, and oil flows into the plunger. Oil is also metered thru the metering valve thru the passages in the push rod cup and it flows up the hollow pushrod. In this position, the drilled hole in the ball end of the pushrod is indexed with the drilled hole in the rocker arm, and the oil lubricates the upper valve train areas.
Judging by this....i'd say your likely culprit for lack of lube up top, and the noise you're hearing are the lifters. Just an educated guess. They can be pulled, dissassembled, and reinstalled. Just be sure to keep them in order, or you risk damaging the cam and/or your lifters with one key turn.
From shop manual:
I was thinking that at first but #1 & #3 intake rockers are getting oil, so I'm leaning more towards a failed lifters
