Battery cable size
Old 05-20-2014, 09:18 AM
78 & 87 Super Cab's Avatar
78 & 87 Super Cab
78 & 87 Super Cab is offline
Question Battery cable size
What is the correct gauge size for the battery cables on My '59 F100 with the 223? The ground cable, and cable from solenoid to starter are both made up from huge 1/0 gauge welding cable,positive cable was gone) I thought these were way too big. So I need to know what size I need to go buy for the cables
Old 05-20-2014, 11:03 AM
Maltman's Avatar
Maltman
Maltman is offline
are you making your own cables? if not then the pre made cables at Napa or any auto parts store should work...I don't know exact gauge to be honest
Old 05-20-2014, 12:20 PM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
Thick battery cables were used with 6 volts, 12 volt battery cables are much thinner.
1957/60 F100/600:
Positive battery cable-battery to starter relay: 19 1/2" long / Negative battery cable-battery to ground: 18" long.
Old 05-20-2014, 01:25 PM
78 & 87 Super Cab
These were on the truck when I got it, I suspect previous owner put those on it.
1957/60 F100/600:
Ok thanks for the info!
Old 05-20-2014, 04:27 PM
Danleig's Avatar
Danleig
Danleig is offline
BTW - electrically speaking there's no such thing as "too big."
If its an aesthetic thing, then by all means change them.
Dieseloholic1
19
10-20-2018 03:13 AM
Frankiea87
12-26-2013 04:40 PM
blueeyedfordguy
1997 - 2003 F150
10-19-2013 09:07 AM
burley208
11-05-2006 05:32 PM
Quick Reply: Battery cable size
