6.0 Help! I'm Stumped
Old 05-15-2014, 08:42 PM
78fordman's Avatar
78fordman
78fordman is offline
It could but you would get random low circuit codes too. Have you checked for excessive fuel aeration?
Sent from my leash using IB AutoGroup
Old 05-15-2014, 08:48 PM
BigStyle's Avatar
BigStyle
BigStyle is offline
No I haven't. How would I accurately check that? I had just filled up and 10 miles down the road the problem started.
Old 05-15-2014, 08:56 PM
Bullitt390's Avatar
Bullitt390
Bullitt390 is offline
Certified Thread Hijacker
Bad copper washers will allow combustion gas into the fuel system and then aerate throughout the system taking out injectors.
Josh
Old 05-15-2014, 09:02 PM
BigStyle's Avatar
BigStyle
BigStyle is offline
Gotcha. So no more testing until I have the new oring kits.
Old 05-15-2014, 09:13 PM
78fordman's Avatar
78fordman
Bad fuel?
Old 05-15-2014, 09:15 PM
BigStyle's Avatar
BigStyle
BigStyle is offline
It is a fuel station I have used many times. Also a friend of mine continuously fills up at the same station. He has a dodge, but he has not had any issues. Very frustrating dealing with the 6.0 I much prefer the 7.3's I've had in the past. Only time the hood was up on them was to change oil and top up washer fluid!
The 6.0...not so much!
Old 05-15-2014, 09:23 PM
Bullitt390's Avatar
Bullitt390
Blaming the 6.0 because you removed injectors and re-installed without new crush washers or o-rings?
Josh
Old 05-15-2014, 09:29 PM
BigStyle's Avatar
BigStyle
BigStyle is offline
No..because I've put more money into 1 6.0 than into the previous 5 7.3 combined!
Old 05-15-2014, 09:35 PM
BigStyle's Avatar
BigStyle
BigStyle is offline
Also, if it were aeration would that cause it to not start when its warmed up? Acts more like an oil leak in the high pressure side. No injectors have any deterioration of the oring from a leaking rail.
Old 05-16-2014, 05:37 PM
BigStyle's Avatar
BigStyle
BigStyle is offline
So today I changed injector one out with injector 7. The imbalance code shifted to injector 7. However, it still would not restart after getting warm. HPOP pressure is around 350psi when cranking when hot. I assume since before I pulled any injectors I didn't have this problem It must be a bad o-ring between the injector and the oil rail.
So is it possible that the seal is bad on the injector with the imbalance (which isn't there cold) and that replacing that seal (well all on that side) could quite likely fix the problem with the imbalance too?
Old 05-16-2014, 07:11 PM
9228.bobcat's Avatar
9228.bobcat
9228.bobcat is offline
I hate 7.3's. Biggest pos out there.
Old 05-16-2014, 10:50 PM
BLADE35's Avatar
BLADE35
BLADE35 is offline
You may have a HPO Leak if the IPR% was 28% and Truck was EOT Above 185*f
PLUS those washers need chnge
Sounds like the Diagnostic was Corupt That always costs extra
jblank
1999 to 2016 Super Duty
12-09-2018 12:28 PM
7.3 forever
187
08-17-2017 08:51 PM
dmanser
08-26-2010 08:46 PM
Darel
11-21-2004 09:43 PM
Quick Reply: 6.0 Help! I'm Stumped
