1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Tow Mirror Swap
Old 05-13-2014, 09:58 PM
Jude Hosey's Avatar
Jude Hosey
Jude Hosey is offline
Post Tow Mirror Swap
Got a question i haven't been able to find an answer to. Has anyone ever put 2008+ power tow mirrors (w/lights) in a 2000 XL model without power mirrors. Any help would be appreciated. Thanks!
Old 05-13-2014, 10:14 PM
02expy's Avatar
02expy
02expy is offline
I have yet to see a write up for adding power mirrors. Some have said the harness is in the door.. If that is the case there is a write up for wiring the 08+ to the older switch. The lights are easy to add. And bolting the mirrors on takes minutes
Old 05-13-2014, 10:17 PM
Jude Hosey's Avatar
Jude Hosey
Yea i've done the swap from the small paddle mirrors to manual tow mirrors already, just interested to see if it's possible to put in lighted 08+ style. If not any idea how to add the 04-07 lighted mirrors? Not worried about heated mirrors.
Old 05-13-2014, 11:42 PM
ketel0ne's Avatar
ketel0ne
ketel0ne is offline
Old 05-14-2014, 11:48 AM
Jude Hosey's Avatar
Jude Hosey
Thanks alot!
Old 05-14-2014, 08:33 PM
SD Dually's Avatar
SD Dually
SD Dually is offline
I'm getting ready to install the (power, heated, lighted) mirrors on my XL, my XL does NOT have any power mirror options at all and the harness is not inside the door, I've looked.
What I will be doing is hooking up what I want myself, I will be hooking up the running lights, turn signals and heat.
The running lights will be tied into the running lights I have added on my running boards which are tied into the trailer harness.
Turn signals will be tied into the turn signals on the truck (hoping it doesn't trip the BCM)(cannot tie into turn signals on the trailer harness because the turn signals on the trailer harness are also the brake lights).
The heat will be run off of a switch coming straight off the battery with fuse.
As far as the power glass, I will not be hooking it up as I have no interest in it.
SD Dually
Old 05-15-2014, 10:13 AM
Jude Hosey's Avatar
Jude Hosey
Talking
Thats exactly what im looking to do, i would really appreciate if you would post pics/steps of how you do it it.
Old 05-17-2014, 03:27 PM
SD Dually's Avatar
SD Dually
No problem, will do.
I should get them in about a week.
SD Dually
Wayne64
2009 - 2014 F150
12-31-2012 10:02 AM
Rob.D
2009 - 2014 F150
21
11-18-2012 02:46 AM
dzirkelbg
20
06-11-2010 01:50 PM
08FX4 off road
05-31-2009 12:09 AM
KTM Racer 99
10-03-2004 03:02 PM
Quick Reply: Tow Mirror Swap
