electric trailer brake question
Not really sure where to put this on the forums but this looks like a good place to start. So trying to get the trailer ready for the long trip. checked all the wiring and replaced both sides of the electric brakes. when i hook up the trailer to the truck to test the brakes they dont really work. I jack up one tire and spin it then hit the brake in the truck and the tire keeps spinning. after a little bit the brake will lock up. I can hear the magnet engaging in the drum but its not slowing the tire down at all. is this how its suppose to work?
could this just be an adjustment i need to make on the shoes or could it be something else. My truck is a 2013 f150 so it has the built in brake controller. any ideas?
Tim
Tim
How did the brakes behave before you changed them? If they were engaging properly before but not after, I'd say it's an adjustment. Also, check the gain setting on your brake control.
On third party brake controls, you could set how quickly the trailer brakes engaged. I wonder if the integrated control does this automatically and somehow takes the speed of the vehicle into account. If it did, that would explain why your test isn't working. Trying taking it to a parking lot (or dirt lot if you can) and manually engaging the trailer brakes to see what happens.
Ok so i have hooked up the trailer and drove it. I was coasting down the road and held the control to 100% trailer brakes adn nothing at all. the factory setting for the controller is at 3.5 out of 10 when i first hook up the trailer. then i can adjust if from there. even on ten it dont work.
fuses and relays are all good i have checked them a few times just for piece of mind. but there is nothin wrong with them
Tim
Tim
well taht is the last time i listen to the manufaturer on stuff. I was told the brake kits i bought were already pre adjusted. well they were not, i adjusted the hell out of them last night and finally got the brakes to work. Thanks for the help ya'll, i let ya know how the trip goes.
Thanks again.
Tim
Thanks again.
Tim
Metal twister
Fifth Wheel & Gooseneck RV Towing
11-10-2017 09:27 PM
elkarcher1716
05-13-2014 08:11 AM
