1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
2001-F350-Diesel-Starter Problem
Old 05-10-2014, 05:41 PM
desertjim's Avatar
desertjim
desertjim is offline
Hi Everyone,
When I try to start my truck, all I get is a CLICK down around the starter. I haven't pulled the starter yet because I wanted to ask you folks about it.
My batteries are good! I replaced the starter less than a year ago, I think, but I can't find the paperwork or anything to indicate when or from whom I purchased the starter. BTW, the truck only has 87k on it.
You youngster won't have any idea what I'm about to say here, so go ahead and turn your head . Back in the day, I had to rebuild many solenoids. It was easy! Just take the thing apart and reverse the copper washer which made the contact, and you were off and running again. I haven't looked at or into any solenoid in more than fifty years probably, but the point is.........that's the same sound the starter makes (like it did back then). So...........
1. Does it sound like a solenoid?
2. Do I need to remove the starter to take off the solenoid?
3. Whaddaya think in general?
I'm gonna have a worker of mine who is helping me do a barn addition pull it Monday. I gotta have that sucker running again. Can't go to the flea market to set up without it.
Donka!
Old 05-11-2014, 01:58 AM
1969furd's Avatar
1969furd
1969furd is offline
try this. take a hammer, and GENTLY tap on the starter body then try and kick it over see if that works, if not then id try the sylanoid
Old 05-11-2014, 07:15 AM
Hotrod70d's Avatar
Hotrod70d
Hotrod70d is offline
If the wires are not corroded at the starter . My have a dead spot in the selenoid. Hitting with a hammer while trying to turn it over is short term to getting it started . Also 2 people are required. Hopefully just the wires. They make acid cleaner in a spray then get a protective coating for wires
mOROTBREATH
18
09-24-2013 07:01 PM
oldmaninva
General Automotive Discussion
03-28-2006 06:21 PM
brs127s
01-06-2004 09:46 PM
haniszewski
03-31-2003 01:46 PM
Quick Reply: 2001-F350-Diesel-Starter Problem
