injector clean/rebuilding..
So I know there is another thread started on injectors
https://www.ford-trucks.com/forums/s....php?t=1302926
My question is I have a set of B code injectors on the shelf that I would like to rebuild... Some of the injector bodies are wet just how I pulled them from the truck, is it because I had leaking return lines? Or is there more to wear out? Like the bodies themselves? I have access to a pop tester and plan on setting them around 2000 psi or so.. And if the question gets asked, yes my injection pump is fresh. here is a picture of the injectors
The truck ran smooth and quiet with these old injectors in there, it just smoked a lot
Olds64
11-06-2018 10:38 AM
