I'm guessing you have a 4r70w because I don't believe the 100s made it into the light trucks except for the Navigator. Great trans either way. The hydraulic ones are very reliable.
Sometimes, I am stupid. Trans code is E. And just as an FYI, my local parts store lists all three transmissions, 4R70, E4OD and 4R100, as being available in 1998.
The 4r100 is the updated E4OD given a new name and uses different fluid specs and internal disc and band materials plus changes in various connecting and calibrations to meet the model years advancements.
Good luck.
Mine came with the E4OD 10/98. I had it rebuilt and fully updated installing the 6 gear steel planetaria's instead of the stock 3 gear aluminum ones where the splines can strip out. The shop said it was virtually an R4100 now. It's a great trans. The original lasted 177,000 before the clutches burned out.
