How to add a 3 seat to the front
I don't see why it would be so complicated, Ford offered plenty of SD's with the 40/20/40 or whatever bench up front. Find one at a scrapyard, tuck the center console wiring under the carpet once you yank it out, and throw in the bench. Maybe some risers to clear the trans hump but I don't see that being an issue...
Out of curiosity, why do you NEED to add another seat to something that can already hold 8 people in good comfort? Not trying to start ****, merely curious.
Either way, this may help: https://www.ford-trucks.com/forums/s...92&postcount=9
quick search came up with this on ebay:
99 07 Ford F250 F350 F450 F550 Front Gray Vynil Bench Seat | eBay
I would honestly check the local pick-a-part or junkyard first.
on
Did you figure out what you need to get this done?
If not, I have done it and have been using the seat. Yes you will need to take off the arm rests and cut off the posts on your 40 seats, they will be in the way.
I have also done this same thing in an Expy. I was able to go with a 2011 and newer seat with the shoulder belt and head rest and would say that is a way better seat.
You would need to find a 2011 jump seat from an F series. There are always lots on ebay, or check your local wreckers. The wreckers seem to have a harder time to sell just the 20 seat tho.
The newer seat might also need to have the seat bracket changed a little to fit, as it looks like the base is different. My thought was to have the base from my older 20 seat, but I have not purchased a 2011 seat yet. Well, I had one on the way from ebay that got stopped in shipping and I have not pursued another one yet.
Here is my 9 seater build with Pics it the link works.
https://www.ford-trucks.com/forums/1...l#post12914253
kevin.ford-trucks
03-07-2014 10:27 PM
