Seat swap help
Seat swap help
I want to do a seat swap in my 88 crew cab. I need help with which seats interchange and what mods need to be done if any
I found this seat in a single cab brick nose
I found these buckets for an extended cab brick nose
And I found these buckets from a 92 crew cab
What cab configurations and body style trucks interchange?
FYI, whatever seat I choose will be recovered so condition and color doesn't matter
A crew will have four bolts on the bottom frame. Not 8.
Also they will NOT not into your truck.
In order of them to bolt into your truck, you would need a seat pan from a reg cab or crew cab that had a 40-20-40. You will ALSO need the seat tracks from the 40-20-40 as well. the super cab tracks will make the seat sit 2-4" higher
