Modular V10 (6.8l)
2009 & Later V10 Variable Timing?
Old 04-22-2014, 08:38 PM
Pool Guy 23's Avatar
Pool Guy 23
Pool Guy 23 is offline
I learned the hard way that my 2006 F150 with the 3 Valve 5.4 engine uses a variable timing system that reads off the oil pressure. The engine had 150000 miles on it, but always runs great. I changed the oil before a trip with my small 5th wheel and got into traffic and the truck began stumbling and died. Fired right back up and ran fine about 1000rpm, just would not idle. I found solution in posts that it was the oil pressure dropping too low (below 25 lbs) which caused the timing to change, so posting advice was to put in a slightly heavier weight oil, which solved everything immediately. As I am looking to buy a 2009 or later F350 Super Duty 2WD Dually with a V-10 and want to know, does this engine have the two piece spark plug problem or the variable timing/oil pressure issue like the 5.4?
Old 04-22-2014, 08:57 PM
nojoke327's Avatar
nojoke327
nojoke327 is offline
I don't think anything after mid 07 had the plug issues. Not sure on any oil pressure issues though
Old 04-22-2014, 10:41 PM
LSCR351's Avatar
LSCR351
LSCR351 is offline
Spark plug issue was fixed in 2008. V10 never got the VVT. 2008-2010 V10 is your truck to buy!
Old 04-23-2014, 10:31 PM
rdinmv's Avatar
rdinmv
rdinmv is offline
its too bad the v10 never got vvt, imagine the low end TQ it could have gained, hey Ford where is our 7.8 liter coyote boss 520 hp 550 ft lb v-10?
Old 04-23-2014, 10:57 PM
LSCR351's Avatar
LSCR351
LSCR351 is offline
Uwh! Yeah Ford, I want a 6.2 with 2 more cylinders glued on!!!
Old 04-23-2014, 11:01 PM
LSCR351's Avatar
LSCR351
LSCR351 is offline
And I am just as glad Ford left the VVT off my V10! I see to many ticking 5.4's, including the one I still own!
Old 04-25-2014, 05:10 PM
jesse5's Avatar
jesse5
jesse5 is offline
Oil pressure activated VVT should never have been added to any engine. Electric activation maybe ok, I don't know.
The lackadaisical who miss an oil change by a large margin can ruin a new engine by causing sludge in the small ports that cannot be cleaned.
Old 04-25-2014, 08:17 PM
LSCR351's Avatar
LSCR351
LSCR351 is offline
Oil activated VVT does work, just look at 2000+ Corolla, and many others. Ford just dropped the ball adding it to their great modular motors. Again, so glad they left the V10 out! I Wonder why they omited it anyway?
Old 04-25-2014, 08:28 PM
nojoke327's Avatar
nojoke327
Probably because it didn't need any more low end torque and no one buying them cared about gas mileage like the majority of 5.4 sold in the 150.
Tobygot
1999 to 2016 Super Duty
20
01-10-2011 02:48 PM
krisammarine
Modular V10 (6.8l)
10-19-2010 12:00 PM
lostin90s
22
05-30-2007 11:00 PM
BigFord74
Modular V10 (6.8l)
22
10-24-2005 08:01 PM
Nutz5
07-05-2003 06:12 PM
Quick Reply: 2009 & Later V10 Variable Timing?
