alternator fire
alternator fire
so I was going to get the truck washed, but 2 blocks down the road smoke out of the engine bay.
pulled over popped the hood and the alternator is on fire. extinguished it self out but the burnt electrical smell.....sheesh..
anyways, could I potentially drive the truck to the dealer, or will it catch on fire again????
Yah.....appearantly the 200 amp alternators are notorious for catching fire. The internals fail, and cause a ground to power short. Taking it in for warranty repair. Hopefully they replace all the cables and the batteries.
BTW........if this should happen to someone else, try and disconnect both batteries ASAP. After alternator stops smoking, fire is out, and it's cooled off, disconnect the power cable that goes into the alternator (or in a extreme cituation, cut the red cable and wrap/insulate the world out of it). U can safely drive to nearest shop/dealer for repair. Remember, you are now driving on just battery power, so turn off all electrical components that are not essential to driving, and count your blessings the whole truck didn't go up in flames.
Boil
What you can do check level and Specific Gravity with a hydrometer then cranking amp test. Have a Pep Boy or someone do cranking amp test.
redmangh
01-14-2006 12:18 PM
