to get or not to get... 750 cfm holly dbl pumper...
Yes as the tag says do I get it or not. I am building my 71 Lincoln motor but I want to be able to tow with it and still perform while maintaining some gas mileage. Is 750 dbl pumper too much for the 460. BTW its going in a 75 f250 camper special supercab with c6 2 wheel drive. 200 bucks or said he'd trade for parts... Not sure exactly what yet I would trade for it but yeah tell me your thoughts....
Is 750 dbl pumper too much for the 460? BTW its going in a 75 f250 camper special supercab with c6 2 wheel drive. 200 bucks or said he'd trade for parts... Not sure exactly what yet I would trade for it but yeah tell me your thoughts....
A double pumper squirts all four barrels whether you need it or not... vacuum secondaries will activate based on engine load (like towing) or when ya quickly stomp on the go-pedal.
For a 460 within the typical RPM range for these rigs stick with a 650 cfm to 700 cfm carb... with vacuum secondaries.
$400 buys you a brand new 770cfm if you're okay with that route. Otherwise, it's a matter of checking Craigslist, eBay, and swap meets and hoping that what you're sold isn't leaking or broken. Carburetors are one of the things I'd much prefer buying new.
http://www.summitracing.com/parts/su...FRSPfgod33YAng
Vacuum secondaries and a vacuum advance on the distributor will help mileage. The summit carb will work fine for your situation and it's a good deal. Holley also makes a street avenger series that has vacuum secondaries and electric choke, they are entry level and priced accordingly. The summit carb will be the cheapest new carb you can buy. I have used both with good results, I don't like edelbrock carbs but it's mainly personal preference. I have seen plenty work just fine.
We had a 460 in a f250 with a double pumper and we got 6mpg!
earl92
05-30-2015 03:41 AM
KY_FORD
05-19-2013 02:02 PM
deisele75
02-23-2005 11:23 PM
customline
03-15-2002 09:20 PM
